Log4OM 1.29 released
Release notes Version 1.29.0
MAINTENANCE RELEASE
- LOTW download doesn't change the gridsquare if something it's already saved on the QSO
- Implemented great circle representation when drawing QSO on map
- Winkeyer Lead-In and Tail value increment changed from 10 to 1 per click.
- Hamlib libraries updated to main revision 3.x
- Changed residual dates from LOCAL to UTC on all software features.
- Fixed DXCC export statistics
- LOTW QSO download now updates country if different from log.
- DC reference removed from WAS list
- Fixed code in the awards management to be more compliant with awards.xml file
- Added support to 4m awards in ARRL / CQ awards
- Fixed counter in GRIDSQUARE statistics
- New bands supported in IOTA award (6m and upper)
- 2 new advanced options in SETTINGS - CAT (mainly Elecraft users)
- Send FREQUENCY command before MODE command when changing both parameters
- Add delay (fixed 500 ms) between FREQ and MODE subsequent messages (or MODE FREQ according to previous parameter)
- Added transverter support under program settings - CAT menu (add/remove amount in KHz) working at low level near CAT subsystem.
- Added JT9, FT8 mode support
- Small performance improvements in datagrid QSO visualization
Re: Log4OM 1.29 released
Just installed update. Initial observation/tests with freq and delay options for Elecraft appear to be working like a charm. Testing with OmniRig talking to my K3.
Tnx much Lele, Terry and all on development group.
PE5TT
Post by PE5TT »
Where can i find this ?
I think Lele means the Map in the F7 Window which shows yor QTH and the QTH
of the station you fill in to the Callsign field. The line between those 2 point shows
the exact route between both stations and not only a simple point to point line.
SP9UNX
Post by SP9UNX »
Something wrong is with the label printing for FT8 mode :? . No RST and mode is visible on the label.
Hi SP9UNX (a name in the signature would be useful),
have you changed the modes in one of the last versions of Log4OM ??
If yes you may have a mode_user.xml and a rts_user xml. Those will be
not changed after an update from 1 version to the next.
Please try to copy the 2 Files in the ZIP archive in this german language
thread here: viewtopic.php?f=21&t=2941
It´s the 2nd post with the FT8 Updat.zip.
Unpach the zip file and copy the 2 files to your Log4OM configuration folder.
After a restart try again and and report here. B.t.w. i can´t check this out so
i don´t use label printing ... I fill out my QSL by the good old manual way :D :D
VK4JAZ
Post by VK4JAZ »
I have just upgraded to 1.29 but notice that FT-8 doesn't appear in my mode drop down box of options.
Regards
Grant VK4JAZ
SP9UNX wrote: 03 Aug 2017, 21:37 Something wrong is with the label printing for FT8 mode :? . No RST and mode is visible on the label.
Works for me - Read Juergen's post above
VK4JAZ wrote: 04 Aug 2017, 01:02 I have just upgraded to 1.29 but notice that FT-8 doesn't appear in my mode drop down box of options.
Regards
Grant VK4JAZ
Read Juergen's post above, Log4OM is defaulting to your user file which we don't modify when we update the software because you have changed it to your specific requirements.
There are many threads in this forum about FT8 with full explanations of what to do
check if you have a modelist_user.csv file or a rstmode_user.csv
In that case, delete them, they're probably outdated and they have precedence on main official files, now updated.
