I have searched the post for this and cannot find a resolution.
Issue: After upgrading to 1.29.0.0, DC was eliminated as a state.
When viewing WAS award status, in the top left corner of the screen it shows 51/51 in red.
DC stations worked have have been relocated to the bottom of the screen and in the NAME column (second column from left) it shows ***NOT FOUND... (highlighted in red).
Other than deleting the DC contacts that have been made, it there a solution to resolve the error?
Thanks (and you folks have written a superb program - thanks for that)
Mark - AF7KE
WAS Elimination of DC as a state caused an error.
Re: WAS Elimination of DC as a state caused an error.
"DC stations worked have have been relocated to the bottom of the screen and in the NAME column (second column from left) it shows ***NOT FOUND... (highlighted in red)."
Yes change the incorrect DC state in the 'Not fond' QSO's to the correct ones and everything will be OK
DC contacts should be logged as Maryland for DXCC purposes.
