Web Browser
NR3E
Web Browser
Post by NR3E »
I am trying to understand the logic behind the internal web browser. I like that when you click on the "Lookup" button it opens your favorite call sign database with the current contact listed. That is a cool feature. But when you log the contact or hit the "CLR" button, everything in the web browser is cleared away too. I like to open www.sotawatch.org in the web browser, but any time there is an update, a saving of a record, or any Log4OM activity, it clears away the web page. I would like for sotawatch.org (or any other web page) to stay in the browser until I told it to go away. Is there some setting that I am missing or is it not possible?
Thanks, Ron
Re: Web Browser
Check the box to se the external browser and that wont get cleared
NR3E
Re: Web Browser
Post by NR3E »
Thanks for your response, Terry, your support has been great. When I check the box to use the external browser it does indeed open the Lookup function in a separate browser. But the internal browser window still clears when a record is added or looked up. I can work around that by opening Sotawatch in a separate window and tiling them side by side. I was just hoping the internal browser window would not clear any time there is some activity on screen.
Ron
Re: Web Browser
No the internal browser is designed to function as you describe
Re: Web Browser
Terry can you explain how this works? Are you supposed to be able to enter a call and popup the user QRZ page like some other programs?
Re: Web Browser
kd0zv wrote: 05 Nov 2017, 18:29 Terry can you explain how this works? Are you supposed to be able to enter a call and popup the user QRZ page like some other programs?
Enter a call and when the 'LOOKUP' button becomes live just click it to open the Browser F1 tab or the external browser if selected to view the QRZ page
Re: Web Browser
Thanks Terry !
Did not look over there
