I get the attached error when loading Log4OM. I did get another similar error with another file (IOTA?), but that seems to have fixed itself.
I did update the country file, but the error still remains. I'll keep on trying.
I wonder if it is possible for Log4OM to be made to use a pre-opened version of Omnirig rather than only the one it has just opened. The only crashes (BSOD) that I get are when Log4OM closes when it has loaded Omnirig, which means it closes Omnirig too. I would like to try using a pre-opened example, but it does not. Plus, Log4OM seems to close an independently opened version. I would like to have a continually running Omnirig and see if that will sort things. I realise I will have to wait until v2 if anything could be done about this.
As mentioned previously, this crash corrupts the config.xml to a new-install state.
73 de Guy G4DWV 4X1LT
Corrupt contry file
Corrupt contry file
- 2017-10-28_16h07_58.png (20.49 KiB) Viewed 3072 times
Re: Corrupt contry file
The Country file here is OK. Downloaded to test it and all is OK.
Try downloading it again.
Hi Chuck,
That cleared it. Many thanks.
Normally it´s the first step to try a new download if a file was declared
as corrupted. Not only for files are used by Log4OM ...
I had already tried a download of the file before writing in.
