Text Format on address Box
EC1DQ
Post by EC1DQ »
I've been searching for this matter for a few days now, but I didn't find any reference. It's about the format of the text on the address box. Since a few days ago, the data which comes from qrz.com lost its format. I include two screenshots so you can get the idea. It isn't a big issue, of course, but if there is a way to correct it I will like to know. At qrz.com they said: "We do not provide formatted addresses like that in our data. We provide each component of the address separetely and it is up to the developer (Log4OM) to format the address". So that's it.. any idea?
Happy weekend folks!
EC1DQ
Re: Text Format on address Box
Post by EC1DQ »
Sorry,
I forgot the screenshots
Screen Shot Correct.jpg (60.33 KiB) Viewed 4403 times
Screenshot Bad Format.jpg (61.98 KiB) Viewed 4403 times
Thanks for reporting. I will check.
I confirm those data are published on different rows in the XML answer.
Log4OM compose address merging addr1 + addr2 + state + zip + country fields and separating them by /r/n
I'm checking that part of the code, as it seems responsible for the issue.
EC1DQ
Post by EC1DQ »
Hi again,
I can't say why or how, but the issue dissapeared as it cames... obviously something changed and probably not related to LOG4OM. Thanks for the assistance and if the issue appears again or I find what happened, I will report it.
Congratulations for the good work!
