Hello All!
Having a problem with callsign lookup.
KH1/KH7<any character> returns the country as Hawaii but KH1/<anything other callsign> returns Baker Island.
For example:
KH1/KH7Z fills in correct name, but country is Hawaii.
KH1/KD0Q fills in correct name, country is Baker Island.
Any ideas?
Thanks, Glenn KD0Q
Callsign Lookup not working right
Re: Callsign Lookup not working right
Hi Glen,
don´t know what´s wrong at your side but here is working fine (see screenshot).
B.t.w. which version of Log4OM are you using and all the data files up2date ?
(Country- and SCL-Database under the settings TAB)
I'm using version 1.32.0.0. Just updated all databasse and restarted Log4OM. Same result.
Try your test with KH1/KH7Z instead of KH1/KH7ZZ.
Closely examining the country file, I found the issue and have corrected it the country file dated Jun 28, 2018. User need to download this update.
Thanks for jumping on that Chuck but it still doesn't work for me.
Is it something about having KH1/ instead of /KH1?
I'm looking at a few things on this now. Get back soon. I hope!!
Have checked that here too. If i use KH1/KH7ZZ i will get the correct DXCC Baker but if i use
KH1/KH7Z i have also Hawaii here ....
Daniele is looking into it and hope soon he will have a fix. So, stand by guys.
Update your Clublog database and both calls look up correctly
have tried this but always Hawaii ....
Version is the latest for the test team ...
