Data From FlDigi - Not
k4tty
Post by k4tty »
A new install on Windows 10 with Fldigi 4.0. I am not able to get data passed from Fldigi to Log4OM. Entering a call sign in FlDigi brings nothing back to Log4OM.
The main screen shows two green dots for Log4OM and Communicator. However, the communicator window shows Service status:
Green for TCP
Green for Fldigi outbound
RED for Fldigi inbound (if I click this,it turns green for a few seconds, then turns red again.)
The activity log shows: FldigiManagement Not Found, Function Fldigi Tx.
What can I do?
Peter
Peter
K4TTY
Re: Data From FlDigi - Not
Have you enabled the XML/RPC control in FLDigi?
Did you enable the 'Inbound/Fldigi settings in the Log4OM communicator as shown in our user guide and YouTube video tutorials
k4tty
Post by k4tty »
I am using RigCAT to control the FT-991a. Will Log4OM not work with that rig control?
Inbound FlDigi settings are:
FlDigi Interface enabled - checked
Send frequency to FlDigi - not checked
Read freq/tx from FlFigi - checked
Peter
Peter
K4TTY
Peter
Follow our user guide and video disable all other methods of CAT control in FLdigi and use the XML/RPC facility in FLDigi
Log4OM communicates with your radio using Omnirig and also with FLDigi using the UDP connection to XML/RPC this is fully documented
k4tty
Post by k4tty »
Changed and reset. Same errors.
Thanks anyway.
Peter
K4TTY
Where in the world are you located, cant tell because you dont display a call sign? Let me know and we will arrange a TeamViewer session to resolve the issue.
It must be something on your system that is wrong because many of us use this set up without problems.
k4tty
Post by k4tty »
Thanks for the offer. I'm in Florida, USA. EDT.
Peter
K4TTY
Peter
K4TTY
Boomerm3 wrote: 20 Oct 2018, 12:20 Thanks for the offer. I'm in Florida, USA. EDT.
Peter
K4TTY
Ok now we know where you are let's see if we can find a volunteer in your time zone who will TeamViewer with you.
If not I will do it if we can find a mutually suitable time of day
Seems nobody has come forward so email me at my address on QRZ and we will have to do it long distance.
You will need to install TeamViewer on the computer where Log4OM is located, for me to resolve the issue
