Possibility CAT control of YAESU FT 736R with LOG4OM?
pd1ahm
Re: Possibility CAT control of YAESU FT 736R with LOG4OM?
Post by pd1ahm »
Hello G4POP,
I'm Hans, PD1AHM.
I am curious if there are any developments to support this radio in Log4OM.
Even though they are a bit older, there are still enough in use.
Is this radio still on the schedule to be supported?
73 Hans, PD1AHM.
Log4OM does not provide the CAT control for any radios this function is provided using the Omnirig and Hamlib software integration so you need to ask the authors of those programs if you want a radio added to the lists.
However on checking I observe that the FT736R IS ALREADY SUPPORTED by the Hamlib system so you can connect from Log4OM to your radio by selecting Hamlib in the Log4OM Options/CAT tab and then selecting your radio from the list. See below
