Callsigns in Cluster Scanner not clickable
oe3ide
Post by oe3ide »
Hey,
I have some weird issue since a couple of weeks. If I click a callsign in the cluster scanner window, nothing happens. Normaly simple click should pick the callsign into the callsign field, doubleclick should additionally change freq/mode.
See video: https://www.oe3ide.com/wordp/wp-content ... -45-25.mkv
oe3ide
Re: Callsigns in Cluster Scanner not clickable
Post by oe3ide »
I found the "problem" or reason. I am running also SDR Console V3 (also connected via OmniRig). If I close SDR Console, all works normal...
There seams to be an issue with this kind of setup.
73 Ernst
Install all three programs to run as an administrator by right clicking the instal file and selecting 'run as an administrator'
oe3ide
Post by oe3ide »
Thanks Terry,
already installed & running as Admin... I do this for all applications communicating via cat (direct or omnirig).
I posted this issue also on sdrradio groups, because it only appears with Console V3.
All runs fine with Console V2.3, HDSDR, SDRUno.
I will update this thread, if I (or Simon) have a solution.
73 Ernst
oe3ide wrote: 27 Aug 2018, 10:11 Thanks Terry,
73 Ernst
Ernst,
I just checked and SDR-Radio Consul version 3.0.2 build 1234 works fine for me with Log4OM using Omnirig on both of the radios that I have connected.
My only issue with SDR-Radio Consul is that it does not support my Elecraft KX3 I/Q output so I have to use my RFSpace SDR-IP receiver as a Panadaptor :(
Do you have the latest version of Omnirig installed?
oe3ide
Post by oe3ide »
Ok, Omnirig is the newest one 1.16.
Now I did a install with admin-rights for Log4OM (1.33.1.0), OmniRig & SDRRadio 3.0.2.
Will check it and the next days..
73 Ernst
oe3ide
Post by oe3ide »
Ok, running this setup ~2h shows the same issue... spots in bandmap are not clickable, on 3rd or 4th attempt finally the callsign goes into the inputbox.
Delay of about 2-3 s on clicking spots in the cluster window.
If I switch off/on the tracking in SDR Console, all works normal, at least for a few minutes. After then it starts again.
I am using the Omnirig-Setting FT2000 PEP V3 with this mod:
Code: Select all
[STATUS6]
Command=(TX;)
ReplyLength=4
ReplyEnd=(;)
Validate=(TX.;)
Flag1=(..0.)|pmRX
Flag2=(..1.)|pmTX
Flag3=(..2.)|pmTX
original:
Code: Select all
[STATUS6]
Command=(TX;)
ReplyEnd=(;)
Validate=(TX.;)
Flag1=(..0.)|pmRX
Flag2=(..1.)|pmTX
I need this mod, because with the original ini-file, Omnirig does'nt recognize TX, and so SDR Radio does not mute or reduce IQ data.
73 Ernst
Having spoken to Simon who develops SDR Radio Consul because I discovered the same shortcoming with Omnirig connections.
It appears that you must use a VSP to connect Log4om directly to SDR Radio Consul and SDR CONSUL connects to your radio via Omnirig
I find this a bit limiting because I don't like having to constantly change com ports but at this time it appears that Simon's software does not fully support the multi threading capability of Omnirig.
oe3ide
Post by oe3ide »
OK, thanks for the update.
I will give it a try with VSPE.
