DX Spots In Right Hand Window
G0VSS
Post by G0VSS »
Hi
In the right hand DX spots window I would only like to see the Time / Call Sign and spotter (Or reporter) keeping the 3 mode spot options at the top. I am only interested in DX spotted within my own country (G). I am sure this is the case for most people ? but I cannot see any options for this. Please could you point me in the right direction
Ray
Re: DX Spots In Right Hand Window
Hi Ray,
the right hand cluster window only showing the complete spots for the 3 different main modes.
If you like to use more filters you can do this in the cluster (F9) window. If ther´s not enough filters
you can use special cluster commands in the logon script by editing it.
You find this option if you open Utilities(Cluster ...
By the way, you have to know the syntax of cluster command to use it ;) ;)
We could not implementing all the different possibilities for a complete personalised cluster ... ;) ;)
Apply a filter command to the cluster provider which allows only spots from a spotter in your DXCC entity
See here for filter details http://wiki.dxcluster.org/index.php/DXS ... ing_Manual
And refer to the Log4OM User guide or video tutorials for how to send commands to a cluster server
G0VSS
Post by G0VSS »
Thanks Juergen,
Yes I had a look at the filters but whilst spotter / reporter is in the list I could not see a selection option to specify a spotter country. But Ok on the commands I saw that but not sure of the formatting required.
Thanks also to G4POP I will have a go with that - looks exactly what I need.
Didn't realise there were some videos on some of the subjects.. I will have a look at these too
Thanks to all
Regards
Ray
