Hi All
THis is in the SCL file but shows up in the cluster window as USA. All updates downloaded. Where do I need to tweek the file to make it correct.
Martin
Wake IS
Re: Wake IS
Hi Martin,
Please let us have a specific call sign
The countries shown in the cluster are taken from our country file and if that is incorrect then our country and SCL file guru Chuck K7PT will sort it out
Re: Wake IS
The K9W (Wake Is.) scheduled start is Nov. 3rd. They may have started a day early or it's the international date line issue. They could be plus one day.
Re: Wake IS
K9W
Is in the SCL file but I did not check the date.
Cheers
Cheers
Re: Wake IS
It is in the SCL with a start date of Nov. 3rd as stated on their QRZ web page and per http://dx-world.net/2013/k9w-wake-atoll/
Re: Wake IS
The SCL icon is greyed out. I persume that indicates in the file not active date range. I will edit my file.
Thanks All good support as ever.
Martin
Martin
Re: Wake IS
File updated the current SCL shows Wake as finished.
Cheers
Martin
Cheers
Martin
