I'm trying to get the Worked All Britain award to work in Log4OM 1.39.0.0. I can see WAB listed as an award program in the drop-down when entering a QSO but the drop-down to the right, which I assume should contain the award references, is blank, so I'm obviously misunderstanding something about how this should work.
I would be grateful for some help with this please.
Best 73s,
Dave G7ABT
WAB Award functionality
Re: WAB Award functionality
Thanks for the reply.
No; not sure how this is done (updating).
As far as I can see, the issue is that there isn't any reference data to pull from, but I thought this was built in for WAB.
Having re-read the manual on this and checked other 'built in' awards I see that they all appear to be working correctly with the Reference drop-down populating correctly, so it appears that it is only a problem with WAB; it appears to be populating with blanks as the drop-down does extend down a couple of inches. Am I correct in thinking that the WAB reference data should be built in, or do I need to provide it?
I have tried to do a search on the forum for 'WAB' but all I get the following message:
"The following words in your search query were ignored because they are too common words: wab.
You must specify at least one word to search for. Each word must consist of at least 3 characters and must not contain more than 14 characters excluding wildcards."
I get the same message if I try to search for 'Awards' also.
Data should be there already, try updating awardsDaveH wrote: 10 Sep 2019, 13:16 Thanks for the reply.
Try searching for "Worked all Britain".DaveH wrote: 10 Sep 2019, 13:16I have tried to do a search on the forum for 'WAB' but all I get the following message:
73 de David G4NVB
Works for me, see screenshot below.
I suppose that you have entered a UK call sign?
Thanks Terry/David,
Tried 'Worked All Britain' as suggested and it works, so that's the search sorted; could have sworn I'd tried that, but hey ho.
Updated Awards - no joy. Did a reinstall of 1.39.0.0 ensuring to 'Run as Administrator', but still no change.
Yes, I am using 'G' calls and specifically used the one in your screenshot Terry, but to no avail (QSO Info (F1) set to 20m SSB).
Anything else to try please?
Your input is greatly appreciated.
73s Dave
73s Dave
Check if you have any user files in the c:\.........\roaming\logom\awards folder if so delete them and download awards again, then restart Log4om
Do you see WAB-LG-SQ: WAB Large Award in your drop down list? If so, do you see the Large Squares in the outer Drop down List?DaveH wrote: 10 Sep 2019, 19:07 Anything else to try please?
73s Dave
73 de David G4NVB
Tried that earlier and there was a file there so I removed it, but didn't get anywhere.
I've just done a totally clean reinstall, i.e. uninstalled program; removed database and AppData after copying to a temp folder; restarted computer; installed Log4OM; connected back to old db.
WAB has appeared, so it's now sorted.
Many thanks again for your input.
73s Dave
73s Dave
