Hi
When I tried to enter the pair of frequencies 2.400.258/10.489.758 I get the message "Out of band".
I searched the internet (and the Manual) for an answer to overcome the "Out of band" but no luck.
What should I do ?
Thank you for the all effort in our beahlf.
Vy 73 de
Pedro, CT1DBS/CU3HF
QO-100 Frequencies
Re: QO-100 Frequencies
You need to edit the bandplan_r1.xml file with Notepad to add these frequencies
The file is located at C:\Users\YOUR USER NAME\AppData\Roaming\LogOM
Search this forum for 'bandplan' for information about this
Hi Terry
Problem solved.
Thank you!
Problem solved.
Thank you!
