Hi
I imported an ADIF 3 file from version 1, and the import went well. The correct number of QSO's (1975) appears in the lower left corner. But no QSOs appear in the "Recent QSO" tab. I don't see any filters set. Even when I register new QSOs, they do not show up
All other tabs appear to work properly, including the cluster tab, which shows the correct country, band, and mode status.
Any suggestions?
73 de LA7EHA, Raymond
No QSO's in the "Recent QSO" tab
- log4om.jpg (51.57 KiB) Viewed 2324 times
Re: No QSO's in the "Recent QSO" tab
Have you downloaded the latest hotfix version and read the other posts about this - its resolved by the hotfix
I could not find anything about it, but that doesn't matter. It worked. I installed the fix, deleted my old database file, made a new one, and then imported the ADIF again. Voila!
Thank you.
73 de La7EHA, Raymond
Thank you.
