The ADD button and the CLR button position
KD5UVV
Post by KD5UVV »
Just a thought, not a real biggie but something to consider. Maybe put more space between the ADD button and the CLR button. Or at least put them side by side spaced out a bit. I say this because I've accidentally hit the ADD button and added a call that I had just entered because I heard them on the air and was checking the station out and then found out I either didn't need them or already had worked them and went to CLR them but hit the ADD button instead. (I maybe the only one that have done this) but thought I'd mention it anyhow.
Great program guys, keep up the fantasy work. Thanks to all.
73, foots
Re: The ADD button and the CLR button position
This has been mentioned before and is on our Mantis list.
Meanwhile you might like to use the Esc. key on the keyboard for clear and the Enter/Return key for Add
BTW please let us know your call sign
ESC and ALT-W are more immediate for clear everything.
Buttons are kept for "reference" but they are not intended to be used during normal activity :)
KD5UVV
Post by KD5UVV »
the call is KD5UVV, sorry about that.
