Unless I am not doing something right, I have noticed that My References is being deleted after a QSO edit. I use My References to indicate a SOTA summit when I do an activation. After I save a QSO then maybe see an error that I want to correct, I open the QSO for editing, maybe changing something minor like an RST or a comment. When I save the QSO again, My References is always deleted and shows up blank. I have tried this on several practice records with the same result.
Comments?
Thanks,
Ron, KI4TN
My References Being Deleted
Re: My References Being Deleted
Ron,
When you re-opened the formerly edited and saved QSO did you also click the drop down to again select whatever item you were editing?
Also when you first edited the QSO did you first tic the floppy disc icon to save and then to follow that with a tic on the green checkmark?
I thought I did as you suggested but to make sure, I went back and went through the steps exactly as you listed. Same result. My References was deleted and I didn't even go to that part of the screen. I have some practice records loaded in Version 2. For this, I openened a QSO to edit, used the drop-down to change the RST, clicked the Save icon then the green check. When back at the grid, My References was deleted.
Thanks, Ron
Thanks, Ron
Ron,
Where are you trying to save my references?
Did you read the SOTA part of awards in the user guide?
Yes, I did read the manual!!! I found the information about My References on page 121. That is where I originally saved it. But, when I edit a previously saved QSO, there is a tab titled My References. I can look at my reference there, but if I make any change to the QSO, such as RST, then save the QSO again, My References is deleted. I did not even attempt to change My References when editing another field in the QSO.
Am I doing something wrong?
Ron
Ron
OK Ron I have been able to emulate this is a bug and we will fix itKI4TN wrote: 19 Jan 2020, 22:10 Yes, I did read the manual!!! I found the information about My References on page 121. That is where I originally saved it. But, when I edit a previously saved QSO, there is a tab titled My References. I can look at my reference there, but if I make any change to the QSO, such as RST, then save the QSO again, My References is deleted. I did not even attempt to change My References when editing another field in the QSO.
Ron
Ron,
Problem is fixed and will be in next release in a day or so.
Thanks for spotting that it was a bad issue that we missed in testing
Hi all,
Om another side not sure it is a bug or wanted.
When i go to award manager / edit an award go to reference tab and edit a reference the reference code is deleted so we have to type it again...
73 de F4BPO Greg
GregHS0ZLE wrote: 20 Jan 2020, 09:25 Hi all,
Why and how are you editing the award, examples and screen shots please
I actually edited one of the award i created (DPF)
List of awards and the two i created
Then i edit one of them and go to references as you can see AL the first of the list is properly showing the reference code AL before editing
Once edited the reference code disappear, as i wanted to edit all of them afterwards i had to make my change and re-type all the reference codes as they vanished.
73 de F4BPO Greg
