Log Size limit?
ku3x
Log Size limit?
Post by ku3x »
On the page that shows my actual log, the bottom right hand corner shows the number on contacts I have in my log as well as the maximum log size of 5000 contacts.
So my question is, "can I up the 5000 limit to more contacts, like 10,000 contacts?"
By the way, "Fabulous job on the new software. " I am super impressed to say the least.
Barry, KU3X
sq9jxb
Re: Log Size limit?
Post by sq9jxb »
Welcome Barry
This can be changed.
Click on the padlock icon (it will turn red) and enter 10000,
Then click the icon again and it's ready.
Regards
SGC PowerClear, EMU0202
73!
Jan SQ9JXB
HB9VQQ
Re: Log Size limit?
Post by HB9VQQ »
Be careful setting this too high, consumes quite some cpu cycles.
Flex 6600 - Spiderbeam
va3vf
Re: Log Size limit?
Post by va3vf »
roland wrote: 20 Jan 2020, 19:06 Be careful setting this too high, consumes quite some cpu cycles.
Correct...I still do not see a reason to use more than 100.
What am I missing?
Vince
Re: Log Size limit?
sq9jxb wrote: 20 Jan 2020, 18:25 Welcome Barry
Regards
The padlock action is unnessary that a QSO delete security lock
Just click in the field that displays 5000 and change the number
You can change the default 5000 DISPLAY quantity in the program configuration menu
Re: Log Size limit?
va3vf wrote: 20 Jan 2020, 19:23
What am I missing?
Vince
Nothing! 100 to 200 is perfectly adequate
G1YBB
Re: Log Size limit?
Post by G1YBB »
Does changing the 5000 to zero remove any limit like in v1?
Steve
G1YBB
NN7D
Re: Log Size limit?
Post by NN7D »
G1YBB wrote: 22 Jan 2020, 21:00 Does changing the 5000 to zero remove any limit like in v1?
Steve
G1YBB
That is correct. Same behavior as V1.
Doug
W7DRM
