Dear Terry, Danielle,
Each time I import an ADIF of a contest (I use Win-Test) for contest it will never import the contest sent / received field.
For example for this week end contest ARRL 10M I imported my contacts and all serial numbers are skipped.
Anyway to include them ??
Same it will not take the "notes" filed of ADIF as comment is it normal ?
One example of a contact extracted from Win Test
<CALL:6>JI1LET <QSO_DATE:8>20131214 <TIME_ON:6>002838 <MODE:3>SSB <BAND:3>10m <FREQ:6>28.567 <RST_SENT:2>59 <STX:1>1 <RST_RCVD:2>59 <SRX:3>038 <TX_PWR:3>100 <NOTES:8>ARRL 10M <CONTEST_ID:7>ARRL-10 <EOR>
To sumup STX and STX are not fetched same goes for "notes"
Contest Received / Sent
73 de F4BPO Greg
Re: Contest Received / Sent
Ok I think I found the issue for the comments by looking at the ADIF specifications, it should be in the field "comment" rather than "notes" thus it is an issue from Win Test not Log4OM
Next time I will mass update the adif file before importing by changing all "Notes" into "comment".
Still STX and SRX are not fetched.
73 de F4BPO Greg
Hi Greg,
Please email me the ADIF file.
So often we find that contest loggers either send the data in the wrong field or don't send data at all, every contest logger has a shortcoming one way or another
Greg was not displaying the correct fields in his logbook, easily done because there is a received and sent # for the exchange numbers and a received and sent without a # for the suffix.
