Max,
What version number are you using?
V2 - no spot in Cluster (F8)
Re: V2 - no spot in Cluster (F8)
2.1.0
Terry I can't understand what it depends on.
Now I am monitoring clusters and my internet connection.
I want to be sure that it doesn't depend on problems with the WEB.
Max IK0TIX
Max IK0TIX
I am struggling with this one because it is so random and even intermittent for some users
I got a doubt ... I tried to change the port of the cluster server (from 23 to 80) the system restarted instantly.
I don't know how much this can affect, but generally port 80 is open by default
instantly
instantly
Max IK0TIX
Max IK0TIX
even with port 80 the problem happens again.
So changing the server port does not solve definitively but every time I change it and reboot everything comes back ok.
However, I don't exclude that the problem is on my internet network
Max IK0TIX
Max IK0TIX
After several days of using V2 the cluster screens continue to work as expected. Spots showing on the F8 Cluster tab on the main UI and in the external Cluster window. It's an elusive bug alright. I updated to v2.2 yesterday also. Again thanks to Doug for spending a chunk of his afternoon with me last Monday trying to track down the cause.
Jeff - N9BBE
Jeff - N9BBE
Hi Jeff,
I confirm! since I updated I haven't had any more problems. I leave the cluster active all day, go home and find it still active. This has been happening since Monday.
I always have the doubt that there was also an internet connection problem.
Max IK0TIX
Max IK0TIX
Hello everyone,
what am i doing wrong, i see no cluster messages
73 DL5FCW Gunter
73 DL5FCW Gunter
- Cluster1.jpg (242.42 KiB) Viewed 5202 times
- Cluster2.jpg (143.75 KiB) Viewed 5202 times
Gunter,DL5FCW wrote: 29 Jan 2020, 11:47 Hello everyone,
73 DL5FCW Gunter
Please always say what the version number of Log4OM your using its in the Help/about page
Hello Terry,
i'm using Version 2.2.0.0
Gunter
Gunter
