Log4OM V2 with Version 1
N4PYI
Post by N4PYI »
Is it possible to install Log4OM v2 and continue to run Log4OM v1 simultaneously? Thinking of the transition from v1 to v2. Would allow some time to experiment with v2 while continuing logging with v1 until everything is right with v2.
Thanks,
N4PYI
Brad, N4PYI
Re: Log4OM V2 with Version 1
Brad,
Yes that is the intent. Pls take the time to read the Users Guide, Quick Start Guide and even watch the YouTube videos that Terry did on YouTube about installation and configuration and much more.
BTW ... you will likely be asked / advised to change your login to your call-sign. One of the other moderators may do that and advise you.
It helps all of the members better provide support knowing your approximate location.
Thanks for looking into V2.
N4PYI
Post by N4PYI »
Nolan,
Thanks for the reply. I actually just found it in the v2 manual as I was reading through it. I want to install v2 and tinker with it before abandoning v1 altogether. It looks great, love the new interface.
Brad, N4PYI
Brad, N4PYI
N4PYI
Post by N4PYI »
Nolan,
How do I change my username? Don't see the option.
Brad, N4PYI
Brad, N4PYI
radioman-ct wrote: 25 Jan 2020, 23:46 Nolan,
Brad, N4PYI
Brad,
I've given a head's up to Doug Munday. He is one of the moderators and can adjust your login and advise you of same.
NN7D
Post by NN7D »
N4PYI wrote: 25 Jan 2020, 23:46 Nolan,
Brad, N4PYI
Brad, I've changed your login to N4PYI . Use the same password to log in.
Thanks!
Doug - W7DRM
N4PYI
Post by N4PYI »
Got it Doug.
Brad, N4PYI
