I have edited several grids on my base computer. I now wish to install Log4OM on my laptop for portable use.
What file(s) need to be transferred to the laptop so that I don't have to edit the grids on the laptop?
Jim- KC4JNW
Transfer Edited Grids to a Second Computer
Re: Transfer Edited Grids to a Second Computer
Hey Jim,
I assume you are referring to the table layouts in the various Log4OM windows, right ?
If you click on Help --> "Open config folder" you'll find a folder named "user". That's all you need .
Hope this helps
Roland
Hope this helps
Roland
Flex 6600 - Spiderbeam
Found the "User" folder - so the is what I need to bring to the new computer?
Thanks for you quick reply.
Jim KC4JNW
Jim KC4JNW
Jim, if you just need the layouts just copy the layout_ files.
Roland
Roland
And the config.jsonHB9VQQ wrote: 28 Jan 2020, 15:32 Jim, if you just need the layouts just copy the layout_ files.
Roland
That would not only copy the layouts but all user setttings. But I guess that's probably your goal anyways if you wanna have it on your laptop for portable use.And the config.json
Roland
