Cluster send command not working
Re: Cluster send command not working
Having the same problem. Cluster command is not working. Does not show any of the pre-defined cluster servers. List will not populate to select them. Dan K2DJL
Dan,K2DJL wrote: 31 Jan 2020, 18:58 Having the same problem. Cluster command is not working. Does not show any of the pre-defined cluster servers. List will not populate to select them. Dan K2DJL
What version of Log4OM V2 are you using?
Latest version 2.2.
I have also uninstalled and re-installed 2.2. Same problem. Dan K2DJL
Make sure you send to all servers if you have a localhost set as your primary.
Makes no difference, same problemMake sure you send to all servers if you have a localhost set as your primary.
Flex 6600 - Spiderbeam
Dan, do you have TeamViewer installed? I will PM you to set up a remote session, if you are available.K2DJL wrote: 31 Jan 2020, 19:49 I have also uninstalled and re-installed 2.2. Same problem. Dan K2DJL
Doug - W7DRM
Doug: I don't have TV installed. Dan K2DJL
Dan,
Can you post a screen shot of your Configurations, Cluster tab settings?
TeamViewer is a free program for non-commercial use.
Doug - W7DRM
Doug - W7DRM
I spend some time on the phone with Dan, on the issue of few if any Clusters were showing in the list of Clusters in the Cluster Management window, Connection tab. Dan had actually discovered why this was occurring just prior to the call. In the Configurations, Cluster tab, he had selected "Show User Defined clusters". Once he changed this back to "Show stable clusters", all the clusters were displayed in the Cluster Management window.K2DJL wrote: 31 Jan 2020, 18:58 Having the same problem. Cluster command is not working. Does not show any of the pre-defined cluster servers. List will not populate to select them. Dan K2DJL
So, "Show User Defined Clusters" will ONLY show User Defined Clusters. Meaning those clusters which you have modified with changed Initialization Commands, or SSID, etc. Those clusters thus changed, appear on the Cluster Management, Connection tab with a Bracketed "U" in front of the cluster name. I learned something on this one!
Thanks Dan!
Doug - W7DRM
