Hi All
Why does it take so long to get the cluster information on screen?
In the old version v1.40 were the cluster information faster on the screen.
How can I force this telnet cluster command SHOW/DX 100 when Log4OM starts?
Did I miss some cluster settings?
Best 73 de HB9RYZ
Wolfgang
Built-in Cluster
Built-in Cluster
- Cluster_Screen_v2.JPG (60.03 KiB) Viewed 5654 times
Re: Built-in Cluster
just one - VE7CC-1 - Telnet 23
Which Telnet-Cluster is the best one?
73, Wolfgang
73, Wolfgang
VE7CC is fine there must be something slowing it down, perhaps you could let us have your logfile?hb9ryz wrote: 02 Feb 2020, 08:34 just one - VE7CC-1 - Telnet 23
73, Wolfgang
Hi Terry
Attached my log-file
73 de Wolfgang
73 de Wolfgang
LOG4OM2_log_UI_20200202.log
- (42.29 KiB) Downloaded 327 times
Well according to your log file it took 5 seconds to load which is not long when you consider that it also has to do a lookup and obtain data for the propogation forecasts - 1 second to connect to VE7CC and 4 seconds to collate all of the data and display it?
Dont forget all version 1 used to do was open and display the spots, no geomagnetic data or anything else so perhaps the time penalty is acceptable if you consider that?
2020-02-02 06:57:27.2625 INFO: [TelnetConnection] : ve7cc.net:23 Connecting to ve7cc.net:23
2020-02-02 06:57:27.2675 INFO: * [#=zBayF$AtStAOiJC0oE0MRChs=][5603 ms] : Recalculating statistics asynchronous process completed
2020-02-02 06:57:27.6975 INFO: [TelnetConnection] : ve7cc.net:23 Telnet connection opened
2020-02-02 06:57:27.7037 INFO: [TelnetConnection] : ve7cc.net:23 IS PRIMARY
2020-02-02 06:57:27.7062 INFO: [ClusterManagement] : ve7cc.net:23 Cluster Login started
2020-02-02 06:57:28.1992 INFO: [#=zmXnmRgVkOfqYuIbuKua9GJl11Ss9] : GEOMAGNETIC DATA (DGD) load from file completed
2020-02-02 06:57:28.2012 INFO: [#=zSbvP7Fe3RzaplJnKUujIHv51nVC0] : Loading Solar data series
2020-02-02 06:57:28.2023 INFO: [#=zSbvP7Fe3RzaplJnKUujIHv51nVC0] : GEOMAGNETIC DATA (DSD) downloading from ftp://ftp.swpc.noaa.gov/pub/latest/DSD.txt
2020-02-02 06:57:28.5930 INFO: [#=zSbvP7Fe3RzaplJnKUujIHv51nVC0] : GEOMAGNETIC DATA (DSD) load from file completed
2020-02-02 06:57:28.5930 INFO: [#=zvGcP6e5G$_r_IQ15AP1fyk6BrCV7QbjF9cc89JU=] : Loading Predicted Solar data
2020-02-02 06:57:28.5955 INFO: [#=zvGcP6e5G$_r_IQ15AP1fyk6BrCV7QbjF9cc89JU=] : GEOMAGNETIC DATA (Predicted) downloading from ftp://ftp.swpc.noaa.gov/pub/latest/Predict.txt
2020-02-02 06:57:28.9875 INFO: [#=zvGcP6e5G$_r_IQ15AP1fyk6BrCV7QbjF9cc89JU=] : GEOMAGNETIC DATA (Predicted) load from file completed
2020-02-02 06:57:28.9980 INFO: [#=zY0n7OsemZ$oxkM3BIApzH3bI3uwwYw$IQQ==] : Calculating HOURLY VOACAP data: JN47ga with 1000.0 watts and 11 sun spots on hour: 6
2020-02-02 06:57:32.0177 INFO: [ClusterManagement] : ve7cc.net:23 Cluster Login completed
Hi Terry
Thanks for analyzing my logfile.
But if I start Log4OM v2.2.0 and go to Cluster, the cluster windows is empty.
How can I force the telnet command "SHOW/DX 100" at start-up. If I do this command in the Cluster Telnet mode, all the spots appears quick in the window.
Best 73
Wolfgang
Best 73
Wolfgang
Open Telnet window, disconnect the cluster. Search for the cluster entry in the list and hit the edit button.
Now you can set other commands to the file. Dont forget to save it.
Hi Juergen
Thanks for the tip
Best 73 de HB9RYZ
Wolfgang
Thanks for the tip
Best 73 de HB9RYZ
Wolfgang
No problem, that´s why we are here for
But tell us (with a screenshot of the commands) it work´s better or not.
