mode difference between log en UI
The QSO was in FT4, in the UI is FT8 showing. After rr73 is it right saved in the log
Re: mode difference between log en UI
Hello OM,
the mode in the UI is the Mode which was setted by the user. It not changes when you are getting the messages
from WSJT-X/JTDX with or without JTalert. If the 3rd party software send the command to log into the database
the correct mode will be stored which is coming in from the external software.
Thanks Jürgen. BTW I do not use JT-alert but GridTracker.
But it´s the same. Log4OM is listening for UDP input and log what comes in. The mode in the main UI
will not be changed ...
