Tallying DXCC totals
WA2SQQ
Post by WA2SQQ »
So, I am quickly realizing that V2 is a far more powerful program than V1 was. On the downside, it seems that certain tasks are now a bit more difficult to perform. This is not a complaint, just an observation that is causing some confusion for me.
For example, in V1 if I wanted to see my worked / confirmed DXCC totals for 160m I’d go to the awards section, select DXCC and select the band / mode and the numbers show up in real time.
V2 seems that it now required more “filters” to be manually set each time.
I wish it was more obvious how to do this. Perhaps in the future we can define common reports as a macro. V2 seems to emulate Excel a lot, and I know it can be done in Excel.
Re: Tallying DXCC totals
WA2SQQ wrote: 03 Feb 2020, 15:48 So, I am quickly realizing that V2 is a far more powerful program than V1 was. On the downside, it seems that certain tasks are now a bit more difficult to perform. This is not a complaint, just an observation that is causing some confusion for me.
Its simple
stats 1.jpg (175.81 KiB) Viewed 3742 times
stats 2.jpg (206.72 KiB) Viewed 3742 times
WA2SQQ
Post by WA2SQQ »
Haven't found that screen yet - Need to try this. Thanks
I wish the manual explained this so clearly.
Much appreciated
WA2SQQ wrote: 03 Feb 2020, 15:57 Haven't found that screen yet - Need to try this. Thanks
Much appreciated
Same images in user guide somewhere around page 79
Guide is searchable, so search for statistics etc
KI5BLU
Post by KI5BLU »
I haven't been able to find any totals for DXCC Challenge though? (V1 had that easily available).
The totals on the right side of the statistics view seem to be the total number of countries but
not challenge bandpoints. Setting the "predefined config" to "CHALLENGE" within the
leftmost tab (Award view) doesn't seem to help?
Tom KI5BLU
KI5BLU wrote: 05 Mar 2020, 09:41 I haven't been able to find any totals for DXCC Challenge though? (V1 had that easily available).
Tom KI5BLU
No Chalenge award needs some work which we did not have time for before the launch
KI5BLU
Post by KI5BLU »
Thanks for the quick reply, makes sense, looking forward to seeing it in later versions then!
Thanks again
Tom KI5BLU
