Log4OM 2.3 - JTDX - no locator
sq9jxb
Post by sq9jxb »
Welcome
I have installed version 2.3.0.0 and there is already one error.
Please look at the picture.
There is no GRID in Log4OM V2.3 and in JTDX.
The configuration I did not change is the same as in version 2.2.0.0
Does not download data from QRZCQ (I have a premium account)
In version 2.2.0.0 the data is shown.
in the attachment log file with Log4OM
No Grid L0g4OM 2.3
Grid - Log4OM 2.2
Log file
LOG4OM2_log_UI_20200203.log
(96.07 KiB) Downloaded 328 times
"I didn't change any configurations in Log4OM 2.3, JTDX and JT_Alert"
SGC PowerClear, EMU0202
73!
Jan SQ9JXB
Re: Log4OM 2.3 - JTDX - no locator
what method are you using to receive callsign? JTAlert? direct from JT messages from application? rebroadcast from JTalert?
sq9jxb
Post by sq9jxb »
IW3HMH wrote: 03 Feb 2020, 19:26 what method are you using to receive callsign? JTAlert? direct from JT messages from application? rebroadcast from JTalert?
Hi Danielle
According to the description from JT-Alert, and with Log4OM 2.2 works without any problem.
73!
Jan SQ9JXB
NN7D
Post by NN7D »
Jan,
Its working fine for me with Log4OM V2.3.0.0. With JTDX and JTAlert.
Please post screenshots of your V2 Configurations, Connections tab. And your JTDX Settings, Reporting tab. And your JTAlert Settings, Logging, Log4OM V2 tab, and the Applications, WSJT-X/JTDX tab.
Thanks,
Doug - W7DRM
sq9jxb
Post by sq9jxb »
ok but not until tomorrow
73!
Jan SQ9JXB
sq9jxb
Post by sq9jxb »
LOG4OM2_log_UI_20200204.log
(21.87 KiB) Downloaded 354 times
W7DRM wrote: 03 Feb 2020, 21:15 Jan,
Thanks,
Doug - W7DRM
Welcome W7DRM
If you analyze the log file from Log4OM 2 that I sent, you will see where the error is.
In Log4OM 2.3 no data from QRZCQ.com was downloaded for a given character, while in Log4OM 2.2 the data is downloaded and there is no error.
In the afternoon, I will paste screenshots of the settings you requested.
Regards
73!
Jan SQ9JXB
sq9jxb
Post by sq9jxb »
Thanks,
Doug - W7DRM
Hello, W7DRM
I attach screenshots of the Lof4OM2, JTDX and JT-Alert settings
With these settings in Log4OM 2.2 everything works as it should.
EDIT: Remote Control : Port 2241
73!
Jan SQ9JXB
sq9jxb
Post by sq9jxb »
Missing log file
(21.87 KiB) Downloaded 368 times
73!
Jan SQ9JXB
HB9CQK
Post by HB9CQK »
I have exactly the same issue: 2.2 showed the locator from QRZ.com fine, but 2.3 is not doing this. Working with JTDX and JTAlert with no configuration changes since Log4OM 2.2.
73, Frédéric, HB9CQK
Mount Rigi Remote Station, FlexRadio, ColibriSDR, Airspy, IC-7800, spe 1.3K - FA
sq9jxb
Post by sq9jxb »
Question to the Development Team.
There is a chance that version 2.3 will have this problem removed with JT-Alert / JTDX or is it better to stay with version 2.2?
I gave all the data and screenshots what was asked and the answer is not there.
And as you can see not only I have this problem.
Regards
73!
Jan SQ9JXB
