Unable to exeute file
N9LJY
Post by N9LJY »
I had an issue upgrading to 2.3.0, this error came up,
"Unable to execute file: C(x86)\W3HMH\Log4OM NextGen\L4ONG.exe
CreateProccess failed;code 740
The requested operation requires evaluation"
I tried a couple time to reinstall and same happens! After starting Log4 and WSJT and JTAlert, Log4 hangs up when you click on Log4 to clear a call. Not sure what's going on. Tom.
Re: Unable to exeute file
I think it said elevation in which case you should right click on install file and select 'Run as an administrator'
N9LJY
Post by N9LJY »
Fixed!!
