I assume this should illuminate "New one" on the top?
As you can see below in cluster this is a new country for me. However its now showing up as new one.
Either this is related to my installation or that particular country because I just helped a local ham setup Log4OM V2 and he has seen "new one" work.
I suspect it might have something to do with LOTW confirmation? I have worked the country but do not have LOTW confirmation yet.
I am running view by LOTW in the cluster but maybe the above is ignoring it?
Operator setting I am missing?
New one not working
New one not working
- 2020-02-07_11-26-49.gif (130.79 KiB) Viewed 1808 times
Re: New one not working
If you select worked instead of LOTW it would work as you expect
Actually then both would work opposite as would I want.
Until I have LOTW confirmation I consider it still to be a new one needed.
In my opinion that top section should be user definable or follow the other filter.
Because until I have LOTW confirmation I would still consider it a new one.
