Manually Inputting Logs
I have quite a few contacts to manually input into V2. Did a search for "manual input" and wasn't able to find any specific tips for doing this, where such things as date / time / band and freq are manually inputted w/o any intervention from LOG4OM. Suggestions?
Re: Manually Inputting Logs
I love Log4OM but the thought of entering a bunch of files manually makes my head hurt.
I might consider entering them into an Excel file and there are Excel to ADIF converters out there that would make an ADIF file that Log4OM would import.
If I were you I would wait until we can refine manual input, you can do it now but we will make it easierWA2SQQ wrote: 09 Feb 2020, 21:51 I have quite a few contacts to manually input into V2. Did a search for "manual input" and wasn't able to find any specific tips for doing this, where such things as date / time / band and freq are manually inputted w/o any intervention from LOG4OM. Suggestions?
I’ll take your advice Terry. Thanks
Am I correct that while can import ADIF files, at this time V2 can’t merge an ADIF into an existing file?
You can merge ADIF files into existing Log4OM log. I do it every contest.
Run N1MM for the contest and after contest I export the ADIF file and import into Log4MM
Not merge as in updating existing records with records of the same QSO'S but with updated information like QSL status etcWA2SQQ wrote: 10 Feb 2020, 00:18 I’ll take your advice Terry. Thanks
You can add new records containg different QSO'S to and existing database
I used FLE "Fast Log Entry" by DF3CB. Take a look: https://df3cb.com/fle/WA2SQQ wrote: 09 Feb 2020, 21:51 I have quite a few contacts to manually input into V2. Did a search for "manual input" and wasn't able to find any specific tips for doing this, where such things as date / time / band and freq are manually inputted w/o any intervention from LOG4OM. Suggestions?
/SM5DGE Joe
Joe
Thank you for sharing this! Hopefully Terry can comment on my questions:
1. So, do you have to configure this program to have each data column in the same order as LOG4OM V2?
2. In the example, I see band, but not frequency. Can you add fields?
3. From doing the export of V1 to the import to V2 I learned from Terry that there are different ADIF. Have you used this with V2 yet?
4. So, once you create the ADIF file, you import it into V2?
BobWA2SQQ wrote: 12 Feb 2020, 16:07 Joe
1. No, not possible.
2. Available fields are displayed in "Options" (Alt + E).
3. Yes, import to V2 is OK. FLE is compliant with ADIF 3.0.6.
4. Yes.
