QSL upload issue
Re: QSL upload issue
Please post last N1MM adif file for that test QSO here so we can analyse
That is right. I am not logging live through Log4OM when using N1MM.G4POP wrote: 16 Feb 2020, 21:23 So you'd using ADIF import instead of the UDP method described in our user guide, I think around page 147?.
ADIF Export from N1MMLogger.net - Version 1.0.8131.0
Built: 2/4/2020 10:06:50 AM
KD0ZV logs generated @ 2020-02-16 21:13:19Z
Contest Name: CQWPXCW - 2020-02-15
<EOH>
<CALL:4>WW0Z <QSO_DATE:8>20200216 <TIME_ON:6>211305 <TIME_OFF:6>211305 <BAND:3>20M <STATION_CALLSIGN:5>KD0ZV <FREQ:8>14.02500 <CONTEST_ID:9>CQ-WPX-CW <FREQ_RX:8>14.02500 <MODE:2>CW <RST_RCVD:3>599 <RST_SENT:3>599 <TX_PWR:3>100 <OPERATOR:5>KD0ZV <SRX:1>2 <CQZ:1>4 <STX:1>1 <APP_N1MM_POINTS:1>1 <APP_N1MM_RADIO_NR:1>1 <APP_N1MM_CONTINENT:2>NA <APP_N1MM_RUN1RUN2:1>1 <APP_N1MM_RADIOINTERFACED:1>0 <APP_N1MM_ISORIGINAL:4>True <APP_N1MM_NETBIOSNAME:6>OFFICE <APP_N1MM_ISRUNQSO:1>0 <EOR>
<EOH>
ADIF import doesn't trigger automatic uploads. Those uploads needs to be made with the upload functionalities...
If you upload them and you receive a "dupe" error we have 2 possibilities...
a previous upload didn't updated the status correctly into Log4OM or something "else" uploaded the qso...
i'm trying to reproduce that... Please note that ADIF import will not trigger any upload, but other operations like ADIF monitor does.
QSO are not uploaded immediately... they're queued in background and uploaded after 1 minute or so. For some services, one by one...
There is the possibility that you loaded ADIF with monitor and triggered upload, then while log4om was uploading QSO you made a massive upload?
You can see if there are "pending QSO for upload" in the HELP -> OPEN DIAGNOSTIC FORM.
On the bottom of the screen there is a "Queued QSO for upload | Queued QSO for ADIF" (means adif export
OK well it cant be a previous upload because my "test" contest was imported and I went straight to QSL manager and tried to upload manually. I got error message right off the bat.
This might have been an issue with V1 as well as my contacts without YES status was about 2500 and I am guessing those are all contest contacts that I imported with ADIF.
Try using the UDP method which logs to Log4OM as you log each QSO in N1MM and uploads to online services
EDIT ..IGNORE this. QRZ worked. See examples below. Sorry
I was going to but it appears you have to remove CAT control during the contest and then change it back??G4POP wrote: 16 Feb 2020, 22:05 Try using the UDP method which logs to Log4OM as you log each QSO in N1MM and uploads to online services
I posted about it here but got no answer.
https://forum.log4om.com/viewtopic.php?f=31&t=4758
Oops above example was a bad
QRZ successful. Let me try the other services
OK still getting these messages using the fake contest
22:13:34: Creating clublog temporary file in C:\Users\rmcca\AppData\Roaming\Log4OM2\temp\clublog_20200216221334.adi
22:13:34: Uploading file containing 1 QSO's...
22:13:34: Upload exception. Check log
22:13:34: CLUBLOG END
22:14:52: upload result Invalid token qso: Callsign: WW0Z Date: 2/16/2020 9:13:05 PM Band: 20m Mode: CW
22:14:52: HRDLOG END
From Log
2020-02-16 22:13:34.0342 INFO: [#=zs_5L$5103vtplwNP2mpLEBC2uhsI] : [UPLOAD CLUBLOG LOG] Uploading LOG on CLUBLOG: 1
2020-02-16 22:13:34.0372 INFO: [#=zs_5L$5103vtplwNP2mpLEBC2uhsI] : [CLUBLOG UPLOAD LOG] Creating clublog temporary file in C:\Users\rmcca\AppData\Roaming\Log4OM2\temp\clublog_20200216221334.adi
2020-02-16 22:13:34.0412 INFO: [AdifManagement] : Begin export to ADIF file: C:\Users\rmcca\AppData\Roaming\Log4OM2\temp\clublog_20200216221334.adi
2020-02-16 22:13:34.0442 INFO: * [AdifManagement][2 ms] : Export to ADIF file completed
2020-02-16 22:13:34.0452 INFO: [#=zs_5L$5103vtplwNP2mpLEBC2uhsI] : [CLUBLOG UPLOAD LOG] Uploading clublog file containing 1 QSO's
2020-02-16 22:13:34.5971 ERROR: [#=z7Pnw92oWjN5IIgTOag==][MoveNext] : [EXCEPTION] The remote server returned an error: (403) Forbidden. System.Net.WebException: The remote server returned an error: (403) Forbidden.
at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
at L4ONG.Framework.FWWeb.#=z7Pnw92oWjN5IIgTOag==.MoveNext()
2020-02-16 22:13:34.5971 INFO: [#=zs_5L$5103vtplwNP2mpLEBC2uhsI] : [CLUBLOG UPLOAD LOG] Upload exception. Check log
2020-02-16 22:13:34.6011 INFO: * [#=zs_5L$5103vtplwNP2mpLEBC2uhsI][566 ms] : [CLUBLOG UPLOAD LOG] ###### END ######
From Log
