problem Voice record on air
lz2ao
Post by lz2ao »
Hello,I have complete control on FT dx3000,records on ctrl+f1 ..etc,but when I pressed ctrl+f1 ,only PTT on the rig is turns on ,without my record..there is a record.What to do?
73's LZ2AO
log4om v2.3
Re: problem Voice record on air
Did you have set the correct audio devices in Log4OM setup ?
Correct means the device to what you´re transceiver is listen
to via a modem or internal sounchip ...
This issue started for me on the last update.
Originally it would send the voice message and the PTT would not un-key. After the 2.3 update I am unable to get it to work at all.
I assumed it was still being resolved.
Think that´s another problem. As i can read the PTT switch TRX on but the message won´t sent.
In my eyes that´s a problem with the sound options in the setup.
Actually mine is working now.
The audio channels were wrong. Either they got switched in upgrade or I was messing with them and forgot. I just assumed it was still broke from initial issue. Seems OK
Thanks !
Nice to get a "worked now" ... ;)
lz2ao
Post by lz2ao »
Hello again,we hooked up a usb cable between the computer and FT dx3000, but nothing on the air(no voice,only PTT on the rig is turns on.I don't know how to send you pictures of my settings? I see the button, but how to choose a photo from my computer?
my facebook : Огнян Радев
73's LZ2AO
In windows 10 you can use the snipping tool to make screenshots or you can use CTRL/ALT/PRINT to make a screenshot of the active
window. If you do so you can insert it to Paint or something like that.
By the way, i don´t know the FT-3000 but if it has a integrated soundcard you should have Audiodevices
maybe called USB Audio Codec or something like that. That´s the soundcard option you have to use in
Log4OM that Audio is sent to the transceiver. If the transceiver got audio from a wrong device the sound
could not be transmitted.
lz2ao
Post by lz2ao »
Hello again, i still have the same speech problem on air(no voice).I downloaded a usb driver from the site of Yaesu (CP 210 ).Installed it ,but obviously i don't configure sound card right. I use usb cable and RS232 but nothing happens(only PTT turns on).Can anyone help, i can release Team viewer.
 73's LZ2AO
Do you have any other apps working with the Yaesu USB? Like WSJT=X?
I think its unlikely it is a Log4OM issue if you have the audio output set correctly in Log4OM under Audio Devices and voice keyer.
Have you checked the wave files that are saved to make sure they play on your PC? Need to know if your audio issue is on the recording or playback.
Can you do a screen shot of Audio devices and Voice Keyer?
