Contest mode
KA4CDN
Contest mode
Post by KA4CDN »
I can't get the contest mode to enable. I'm trying to setup ARRL Inter. DX Contest. The date range was good and I've even expanded it. I've got a fixed string entered. It is saved (w/ the disk icon). What else do I need to do?
In image following, I've opened the Contest window (using the Crown) and then opened the Contest Setting dialog to show the settings.
Re: Contest mode
KA4CDN wrote: 16 Feb 2020, 10:03 I can't get the contest mode to enable. I'm trying to setup ARRL Inter. DX Contest. The date range was good and I've even expanded it. I've got a fixed string entered. It is saved (w/ the disk icon). What else do I need to do?
In image following, I've opened the Contest window (using the Crown) and then opened the Contest Setting dialog to show the settings.Capture.PNG
Mike,
Click on the Contest Crown to "enable" the contest you have set up.
KA4CDN
Re: Contest mode
Post by KA4CDN »
I did that. That is what brought up the Contest Log window. Should the "Crown" turn green? Mine doesn't change in any appearance, just opens the new Log window. Seems to do the exact same thing as the main menu Contest->Contest.
KA4CDN
Re: Contest mode
Post by KA4CDN »
OH! I see - there is another Crown in the Contest Log Window. Thanks for the help!
Re: Contest mode
Yes that tricked me too :)
Re: Contest mode
So why is everyone seeing grid disabled?
NN7D
Re: Contest mode
Post by NN7D »
You have not enabled the contest mode. Set up a contest, then open the contest log window, as you have, then click on the Crown icon...
Doug - W7DRM
Re: Contest mode
Same thing Doug.
Contest mode enabled.
Whatever it is I dont think should be there. Not even placed properly.
Re: Contest mode
kd0zv wrote: 21 Feb 2020, 01:02 Same thing Doug.
Try enabling the contest set up like dates etc from the Contest menu on the top tool bar of the main UI before opening the contest window
Re: Contest mode
G4POP wrote: 21 Feb 2020, 07:16
It is.
Makes no sense to me. Can you explain grid disabled please?
