When I click the callsign to work in WSJT-X, it used to pick by Log4OM earlier and his info fetched from qrz.com but not anymore.
Please suggest how to correct it.
I have imported the whole log from WSJT-X accidentally instead of a few missing QSO's. Now I have over 2500 QSO's as Dupes.
Is there any way to remove them quickly or I have to select each one and delete them manually. I have deleted couple of hundred manually.
Thank you very much.
Bhanu
VU2MB
Callsign not picked up from WSJT-X
Re: Callsign not picked up from WSJT-X
Export an ADIF file
Import that ADIF file but with time difference set to 60 sec
Check the box 'Drop existing database
Click import
Click import
Dear Terry G4POP,
Thank you very much for the help. Dupes have been cleaned up.
any clue regarding the second question..
Thank you,
Bhanu
VU2MB
Thank you,
Bhanu
VU2MB
Have you checked our latest user guide 're set up for WSJT?
Constant changes due to variations in interface
Dear Terry, G4POP
Will download the latest one and check it.
Thank you.
Bhanu
vu2mb
Thank you.
Bhanu
vu2mb
Dear Terry G4POP,
Done, Added UDP Inbound msgs and port and its working.
Thank you
Good night
Bhanu
vu2mb
Thank you
Good night
Bhanu
vu2mb
Make sure your not using the adif monitor to read wsjt adif or you will get dupes
