Hi all,
While playing radio today, I noticed on the cluster, 2 stations had little pirate flags instead of country flags, I'm guessing this is either an error, or little oversight, but thought I'd let you know..
The 2 stations are:
Z26FB - https://www.hamqth.com/z62fb
TX5D - https://www.hamqth.com/tx5d
They both seem to be legit, both on QRZ.com also..
G7WFC
Showing little pirate flags
__________
G7WFC
G7WFC
Re: Showing little pirate flags
Which version of Log4OM (Check in HELP/About)
Have you updated the SCL and Country lists to actual stand ?
Ahh sry, the latest 2.4 version, noticed it the day I updated, and I think everything updates automatically, so any lists should be good..
G7WFC
G7WFC
__________
G7WFC
G7WFC
Have moved this topic from V1 to the correct V2 part.
Pirate flags in the cluster are displayed if the country cannot be determined from the prefix.G7WFC wrote: 15 Mar 2020, 20:02 Hi all,
The 2 stations are:
G7WFC
This is because to keep the cluster working at a reasonable speed not ALL sources of lookup are used, especially not on line lookups.
However when the call is transferred to the callsign input field the full lookup process is then carried out and invariably it finds the correct information.
Sometimes the cluster indicators can be incorrect because the user failed to update the datafiles like country file etc or has set the automatic file updates at to greater intervals.
