cluster scanner
4x5hf
cluster scanner
Post by 4x5hf »
Where is cluster scanner function in ver 2 ???
Re: cluster scanner
Its called band map. Its not the same but is the replacement. You will find it under the connect menu.
4x5hf
Re: cluster scanner
Post by 4x5hf »
Thank you! ,73
