ADDING MORE THEN 1 ANTENNA AND 1 RADIO
AH6TX
Post by AH6TX »
uNDER F4 both of the antenna and radio offer a plus button and it looks like you should be able to add additional equipment so as to let contacts know what I am using during the contact. I have tried adding etc but it doesn't work.
Please advise.
Howard
AH6TX
Re: ADDING MORE THEN 1 ANTENNA AND 1 RADIO
AH6TX wrote: 01 Apr 2020, 18:49 uNDER F4 both of the antenna and radio offer a plus button and it looks like you should be able to add additional equipment so as to let contacts know what I am using during the contact. I have tried adding etc but it doesn't work.
Please advise.
Howard
AH6TX
Howard,
You add those additional rigs and antennas at: Settings / Configuration / User Configuration / Station Configuration
KI5IO wrote: 01 Apr 2020, 19:11
Please advise.
Howard
AH6TX
Howard,
You can also add a new aerial or radio in the F4 tab by typing the description into the field and then clicking the + (Plus/Add) button to add it to the drop down list
AH6TX
Post by AH6TX »
Got it....thanks
