Log4OM CAT Control window bug: mode buttons
DK9SAS
Post by DK9SAS »
In the Log4OM CAT Control window, clicking on the text/button "USB" switches the rig in CW-R, clicking on "LSB" switches to CW.
Clicking on "AM" or "FM" selects the correct corresponding mode.
When the rig is in mode "USB-D" for digimodes there's also a green "[DIGITAL]" indicator, which doesn't seem to work as a button.
I'm using OmniRig, which works ok for how far I tested.
73, Sascha
Re: Log4OM CAT Control window bug: mode buttons
DK9SAS wrote: 02 Apr 2020, 02:22 In the Log4OM CAT Control window, clicking on the text/button "USB" switches the rig in CW-R, clicking on "LSB" switches to CW.
73, Sascha
Sascha,
You didn't note which rig you are using with OmniRig. I'm using a K3 and when I click on each of the mode buttons it works as expected. Meaning tapping USB does NOT switch my K3 to CW-R, etc..
May be a rig 'ini' file choice in OmniRig. I know that there are multiple ini files to choose from for Icom and Yaesu rigs.
DK9SAS
Post by DK9SAS »
Nolan, sorry for the late reply.
I'm using my own modified IC-7300 ini file - which works perfectly with OmniRig's own Client.exe (which is the reference implementation, downloadable from the OmniRig site).
I think now I know what's going on:
The problem seems to occur band & frequency dependent - there must be some logic in Log4OM2 that prevents e.g. SSB on 30m or SSB on the CW parts of 20m but switches automatically to CW/CW-R instead.
That might be a little over engineered, since CW filters are too narrow for some digimodes like e.g. FT-8.
73, Sascha
Hi Sascha,
tested this with my ALT-512 SDR by Aerial51. Think it´s not a logic in V2 it´s a bandplan thing. If i´m
in an SSB Part of the bands i can switch to all the different modes but in a CW part i can only use CW,
AM and FM but USB set the TRX to CW and LSB to CW/R.
Think all is working as expected ... ;) ;)
