QSL sent status
PE5TT
Re: QSL sent status
Post by PE5TT »
This is what i did in log4om v1
I set "contest" = "true" for all entry's with "QSL_sent" = "C"
Then i changed all "QSL_sent" = "C" to "QSL_sent" = "N"
and exported the adif
Then i imported the adif in log4om v2
Problem is i can not filter on "contest" in the LOG4OM v2, neither true nor false.
PE5TT
Re: QSL sent status
Post by PE5TT »
I all got it imported in V2, but thing didn't got easier for the thing i want. And I really don't understand why i am not able to filter on the "contest" field in QSL manager ?
I solved it to bulk change the notesfield to the word "contest" in V1 en then import it into V2 for contest QSO's, now i can filter on notesfield qso's in QSL manager.
Re: QSL sent status
PG8M wrote: 04 Apr 2020, 07:21I really don't understand why i am not able to filter on the "contest" field in QSL manager ?
Because there is no longer a 'Contest' field in ADIF only 'Contest ID' so you filter on that, see https://www.adif.org/310/ADIF_310.htm
"ADIF QSO Fields
ADDRESS, ADDRESS_INTL, AGE, A_INDEX, ANT_AZ, ANT_EL, ANT_PATH, ARRL_SECT, AWARD_GRANTED, AWARD_SUBMITTED,
BAND, BAND_RX,
CALL, CHECK, CLASS, CLUBLOG_QSO_UPLOAD_DATE, CLUBLOG_QSO_UPLOAD_STATUS, CNTY, COMMENT, COMMENT_INTL, CONT, CONTACTED_OP, CONTEST_ID, COUNTRY, COUNTRY_INTL, CQZ, CREDIT_SUBMITTED, CREDIT_GRANTED,
DARC_DOK, DISTANCE, DXCC,
EMAIL, EQ_CALL, EQSL_QSLRDATE, EQSL_QSLSDATE, EQSL_QSL_RCVD, EQSL_QSL_SENT"
PE5TT
Re: QSL sent status
Post by PE5TT »
It is still in the table in V2
Re: QSL sent status
Legacy field but not now a valid ADIF field, its there for historic reasons.
