Change in ADIF With TQSL 2.5.1
Re: Change in ADIF With TQSL 2.5.1
N4xyz wrote: 12 Apr 2020, 00:15 Don't know where VA comes from.
VA is correct its Virginia thats wrong and that probably came from an internet look up, an import from other software or by manual input from the user.
Do I change LOG4OM Station Information to VA for future and edit all QSOs to VA in log?
Yes you should use the accepted ADIF abbreviation for both your location and the other stations locations.
If you read the other threads on this subject this is due to the Tqsl update now starting to match state information to the ADIF format
You must also change it in TQSL because that is the real issue, not Log4OM
N4xyz
Post by N4xyz »
Terry, thanks for the reply. I understand that its the TQSL update causing the problem. In TQSL when you are adding a location the State is a pull down menu you select and it is Virginia. I guess TQSL is sending location data as VA.
Dave, N4XYX
