Send spot
VK7AC
Send spot
Post by VK7AC »
if the call sign box is populated with the call sign you want the message to go to and WSJTX is running it will over write the call sign with a new one decoded by WSJTx sending the post to the wrong person is it possible to inhibit this action of replacing the original call sign while the send spot box is activated ?
NN7D
Re: Send spot
Post by NN7D »
Very hard to follow your question.
Call sign box where? Log4OM or WSJTX?
Message to go to? What message?
And WSJTX is running it will over write the call sign? Which call sign?
Which version of Log4OM?
Please explain in detail. Screen shots would be helpful.
Also your name?
Doug
W7DRM
