Export selected QSO's TO ADIF problem
f4flq
Post by f4flq »
Good evening everyone,
I have a small problem with version 2.4.0.0 of Log4OM2.
I would like to export part of my Log to ADIF format.
So I made a filter in the recent QSO view, then I selected the columns I need in the ADIF file, then selected all the QSOs and made an "Export selected to ADIF".
In the created file I have all the columns in the database and not only the selected ones. In the same view I made a
"export visible rows to Excel" and I have only the desired columns.
How to have the expected export in ADIF format?
"ADIF_VERS:5>3.0.8 <PROGRAMID:7>Log4OM2 <PROGRAMVERSION:7>2.4.0.0 <eoh>"
Tnx for your help.
I also tried by QSO Management it's the same.
Re: Export selected QSO's TO ADIF problem
You need to use QSO manager and select the fields for export in the export dialog by checking Export selected fields then checking the fields you require
f4flq
Post by f4flq »
Thank you very much it works like this.
Transferring thread to user support because this was not a Log4OM error
f4flq
Post by f4flq »
Another little question:
Is it normal that the columns selected in the QSO Manager view are not selected by default in the "Export selected feileds" option?
Best 73
F4FLQ Manu
f4flq wrote: 21 Apr 2020, 19:09 Hello
Best 73
F4FLQ Manu
Yes because the user probably requires a different view in log4OM to that fields to be exported
