After i have update to Log4OM V2.2.5.0 it will not send QSO information to Log4om from JT ARLERT anylonger even that it the box is checked
under logging - log4om v2 - Enable log4om V2 Logging : Send WSJT-X DX CALL TO LOG4OM
I have not played around with UDP PORT or anything else . Problem is also when i use JTDX
Any help would be níce
De OZ2LC
JTARLERT Send INFO to LOG4OM
Re: JTARLERT Send INFO to LOG4OM
Check your settings against the information in our LATEST user guide
Thanks Terry that helped
It's always good to check the latest user guide in case of problems
Topic moved from Error Reports to User Support
Never mind i got it to work
