Months I'm using version 2 now.
I had find a file for using ICom IC-9700 with omnirig, and it worked without any problem (also with version 1).
This week I update Log4om v2 to version 2.5.0.0. and now I noticed that the cat control of the icom ic 9700 is going offline. When i start the catcontrol back on it works again. you can change the freq, but after 2 seconds it goes back offline when there is no movement. When i move the vfo it sometimes comes back online.
some info omnirig:
rig 1 : Icom IC-9700 (com4; 115200; 8;None;2;Handshake/High (no change); High; 500; 4000)
rig 2: Kenwood ts-590s (no problem)
has somebody the same problem or a solution?
73's
ON8SI - Simon
Cat Control Icom IC-9700 goes offline after updating to version 2.5
Re: Cat Control Icom IC-9700 goes offline after updating to version 2.5
The problem is solved.
73's
73's
Are you going to share the cause?
These settings work for me, using ver 2.6.1, Omnirig and an IC-9700. It is important to set the IC-9700 CI-V settings carefully and to also check any other log programs still work if you change the 9700 settings. Note few log programs currently have a specific 9700 setting.
On the 9700, under CI-V:
Baud rate 9600
CI-V address 7CH (to mimic an IC9100)
CI-V Transceive OFF
USB/LAN...->REMOTE Transceive Address 00h
CI-V USB Port Link to [REMOTE]
CI-V DATA Baud Rate 9600
CI-V DATA Echo Back
In Omnirig set as:
Rig type IC-9100
Port (whatever your USB connection appears as under Windows Device Manager)
Baud rate 9600
Data bits 8
Parity None
Stop bits 1
RTS High
DTR High
Poll int., ms 500
Timeout 4000
73 Dave
Baud rate 9600
CI-V Transceive OFF
CI-V DATA Echo Back
In Omnirig set as:
Rig type IC-9100
Baud rate 9600
Data bits 8
Parity None
Stop bits 1
RTS High
DTR High
Poll int., ms 500
Timeout 4000
73 Dave
Hey Dave,
I'm using a program Win4ICOMSuite that controls the IC-9700 for several programs like Log4om, SATPC32,...
In the settings '3rd Party SH/HW' you select a port and you also need to put Echo on. When this is off LOg4om disconnects after a few seconds.
So tnx for your info and i use baudrate 57600, but the rest is the same.
73's
Simon
73's
Simon
