hi
it is no so clear to me how SEARCH TAB panel should work in the QSL management/post office window
if you select a data range, there is no other available button to start the search; so what's the functionality ?
for other tabs all ok
tnx
search tab in QSL management
73 de Don IK2EGL
Re: search tab in QSL management
Hi Don, i agree it's not easy to understand... and i will probably change it very soon.
Anyway, open the required area (QSL/EQSL/LOTW)
flag the "Use fields as SEARCH PARAMETER"
set the search parameters in the visualized fields (es. LOTW SENT = Y)
press search button
remove the flag
select required qso to update, set informations of your needs and press save button
press search button
remove the flag
The upload button should not disappear with the filter in use it should always be visible
