I see only an Icon for a private Message. No Icon for an Email
Oh! Perhaps the email icon is only available for moderators? My bad!DF5WW wrote:Hi Mr. T![]()
Many many thanks i was pulling what little hair i had left ... kudosk3dcw wrote:Simon,
Double check that you are using the correct password. You need to be using the password you use to log into the LoTW website, not the password you may or may not have setup in TQSL.
***NOTE: Although TQSL prompts you to setup a signing password, this is not a requirement. You can set it up to sign your uploads without a password (simply hit enter when that dialog comes up during setup) which eliminates one possible mistake. You still must have the password needed to log into LoTW however.
Assuming that you are using the correct password, then log into LoTW and check when those QSLs were received. Then, just for fun, set your download to use the date range download, setting the date to a time before those QSLs were received.
If I had to bet, the problem is with an incorrect password.
Dave
K3DCW
