SOTA Import: Unexpected date format found
HB9GZX
Post by HB9GZX »
I would like to import SOTA csv information (exported from www.sotadata.org.uk). Following the user manual I get an error "Unexpected date format found". I have tried several combinations with the options in the import-window without success.
Attached is the original export csv file from sotadata.
Hope You could help :-)
(System is running in Switzerland)
73 de Dany
HB9GZX_437314_activator_20200720.csv
(1 KiB) Downloaded 215 times
Re: SOTA Import: Unexpected date format found
Log4OM version number please - see help/About
Without that I cannot try to emulate your issue as it could be something already fixed!
HB9GZX
Post by HB9GZX »
Latest version 2.8.0.0
thx a lot
HB9GZX wrote: 20 Jul 2020, 13:30 Latest version 2.8.0.0
thx a lot
Do the QSO's exist in your Log4OM logbook?
HB9GZX
Post by HB9GZX »
No. Stored the logs mobile in Outd Log, exported from there an importer into sotadata. And from there export wirh goal to import into Log4OM
Its a merge routine that updates the existing QSO's with the data from SOTA, its not a way of adding QSO's to your log.
I know SOTA now provide an ADIF upload feature, do they provide an ADIF download? If so download the ADIF and import it from the Log4OM file/Import ADIF menu
HB9GZX
Post by HB9GZX »
This was not clear to me. Now I was able to import as adif to the logbook.
Thank You for Your help.
73 de Dany
