Rig Control
W3LI
Rig Control
Post by W3LI »
Have installed OmniRig to control my Orionll. On the page "OmniRig settings I am ask for information such as Rig Type, Port, Baud, Data Bit, Parity and stop Bits all of which are in the Oll manual.
What is RTS , DTR , Poll Int ms and Time Out ms.
Nothing in the Oll manual or the Log40M user guide.
Tnx, Andy, W3LI
PB4FUN
Re: Rig Control
Post by PB4FUN »
Omnirig is a seperate program.
You install Omnirig and there you select port, baud etc.
Then when you run Log4OM you only have to tell it you use Omnirig.
PB4FUN Meindert; Rig : Icom IC-9100 / Ant: Falcon OUT-250-B @4m AGL; 144 MHz 16 el @ 4m AGL; 70 cm 23 el @ 5 m AGL
Re: Rig Control
W3LI wrote:Have installed OmniRig to control my Orionll. On the page "OmniRig settings I am ask for information such as Rig Type, Port, Baud, Data Bit, Parity and stop Bits all of which are in the Oll manual.
Tnx, Andy, W3LI
When you select your radio (Orion) the RTS & DTS etc settings are set automatically, they are in the Omnirig Orion settings ini
All you need do is select your radio, comm port and baud rate
W3LI
Re: Rig Control
Post by W3LI »
Gentlemen, Thanks for ur help, will try it.
Andy, W3LI
