IOTA Awards Ref missing on ONE qso
k4em
Post by k4em »
I updated 5 QSO's IOTA designator under 'edit qso' , Award refs, the Award pull down had the IOTA listed, I added the IOTA number with no issues.
One QSO does not have the IOTA pulldown under Award Refs, I searched here and the manual. I could not figure it out, how to add the IOTA pulldown for this ONE qso.
Dave
k4em
Re: IOTA Awards Ref missing on ONE qso
What is the call sign of the station
k4em
Post by k4em »
4k5zi
Dave
k4em
k4em wrote: 14 Aug 2020, 09:27 4k5zi
Dave
k4em
OK
The prefix maps to Azerbaijan which of course does not have any islands, hence no IOTA in the awards reference list!
However if you look at the QRZ page for the call sign you will note that it was used in 1990/1991 for Zmeiny (Snake) isl., which is in the Black Sea and therefore in the Ukraine, this activation date is also indicated in the field below the call sign on lookup.
Correcting the country to Ukraine will then provide the IOTA drop down from which you can select EU-182 (Black sea coast group) which includes Snake Island.
I assume this is an old QSO that you are entering manually? because its not been active since 1991?
k4em
Post by k4em »
yes, I found I had not entered the IOTA number for the contact,
Thanks, I will follow your directions.
Great support, Thanks.
Dave
k4em
