Grid Default Row count setting
K2GAV
Post by K2GAV »
After changing this setting in Program Configuration and clicking Save and Apply, the change is not applied. You must close and restart the program for it to be applied.
Not sure if this is considered a bug or is desired, but the result is not intuitive.
Best wishes,
Ted Szypulski
K2GAV
Kenwood TS-990, Elecraft KPA-1500
Re: Grid Default Row count setting
Had you changed or refreshed a grid then the change would be applied, unless of course you had the grid display count in the lower right corner set to a lower value that that which you just set the default to.
