I upgraded today to 2.9.0.0.
The issue persists.
When I bring up Task Manager and watch Log4OM, it isn't really "frozen" -- it is doing things as evidenced by CPU share, disk activity, etc. QSO's "fed" to Log4OM from WSJT-x are captured and properly logged. So the program truly is NOT frozen, it is just ignoring me!
For lack of a better description, (I'm not a software writer, but I played one on TV once) it seems that some process has "stolen" focus and is ignoring the GUI.
I've upgraded back to 2.6.1.0, but will be happy to load 2.9 again if someone can use my support request input.
2.9 and the "frozen screen" issue
- VK7XX
- Old Man
Re: 2.9 and the "frozen screen" issue
Same for me, except that mine was frozen solid and I couldnt do a thing except fire up task manager to shut it down
John
Mine starts up and runs normally for a few QSO's, then just ignores me. The screen/GUI does not show any activity and does not respond to keyboard or mouse.VK7XX wrote: 15 Sep 2020, 06:00Same for me, except that mine was frozen solid and I couldnt do a thing except fire up task manager to shut it downbut I havent gone back to 2.6.1.0 yet, I want to play with the message service when I can...
John
If you bring up task manager and watch the Log4OM line, you can see the program is "doing stuff" as there are changes in CPU, memory, and disk usage by the program.
Like you, the only way to end the program is "end task" in task manager.
Yeah still facing the freezing up issue, had to go back to 2.6.1.0
Hello to all 3 guys ...
still wondering about this issue. Tried anything to reproduce it since 2.7.0.0 was coming up and the
"Freeze" reports are starting. Have tried with or without CAT, have tried with JTDX/WSJT-X including
JTalert, have tried to enable more clusters as i need but always all is fine for me since i start testing
with V2. In earlier Alphas i´ve had some hickups but that was before the first releases was rolling out,
since then no more problems with freezes ...
Still i´ve no idea what´s wrong ...
By the way, meanwhile i have 2 rigs connected to Log4OM 2 via Omnirig and also no probs at all ...
I reported I'm having it also but in the 2.8.0.0 thread. Anyway....to try and help with figuring this out I shutdown JTAlert, turned off the CAT connection, turned off the cluster connection and chat features but it still occurred. I am using JTDX, and only the single UDP connection for port 2333 ADIF is setup in Log4OM.
I upgraded to 2.9.0.0.
First evening all went well. Then I had a windows 10 64bit update and it's freezing again after 1,5 hour.
I like to help. What kind of information do you guys need from me to help to solve this issue.
Roland
Roland
I also get the Frozen screen issue, in v 2.9, although also had in previous versions. Seems to occur if running for a while with WSJTX and JTalert running. Find can close other windows other than the main Log4OM screen, eg QSL Manager QSO Manager can close manually, but the main windows won't close unless kill it off in task manager.
Any users that are still experiencing a program freeze/lockups that would like to try a pre release with refined code please email me direct.
Write to g4pop (at) arrl.net
